which grits?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=22430
Author:  Jody [ Wed May 20, 2009 6:40 am ]
Post subject:  which grits?
What grits of sand paper do you run on your twin drum sander, for sanding top and back plates? thanks Jody
Author:  jordan aceto [ Wed May 20, 2009 8:20 am ]
Post subject:  Re: which grits?
I have 80 and 120/150, although i usually have it set up to only use one drum at a time. I go for 60 grit if there is a lot of material to hog off.
Author:  muthrs [ Wed May 20, 2009 9:02 am ]
Same here.
Author:  Alain Desforges [ Wed May 20, 2009 9:11 am ]
I load mine with 100/120 or 120/150. I prefer the higher grits as I find the lower ones leave me with too much sanding afterwards.
A drum sander is not a planer and shouldn't be used as such. If I have a lot of material to take off, I just take more passes. A good planer is on my 'goodies I want' list...
Anyways, if you try to take off too much material at once, you'll clog up your paper, regardless of grit.
Author:  Jody [ Wed May 20, 2009 4:31 pm ]
cool , thanks Guys! jody
